简介
This guide about removing the battery is fairly straightforward. Be careful to not yank on the connector between the battery and the laptop. Also, make sure that the laptop is turned off before attempting this guide.
你所需要的
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
The battery is located in the bottom right corner of the laptop.
Remove the four .5mm Phillips head screws on the battery using the PH1 screwdriver.
3等其他人完成本指南。
一条评论
Hello, please I've been searching and searching online to get motherboard for Toshiba Satellite P55W-C5316 but i don't seen to find any. Can anyone lead me to get one to buy.
