简介
The back panel is the key piece to remove before any other internal components can be removed. This panel is magnetically attached at the front, so it may close after being opened. Also, make sure to look at the side of the panel where the connectors are to make sure you do not crack the panel while removing it. Follow the instructions to safely remove the back panel on the laptop.
你所需要的
Unscrew the .3mm Phillips head screws on the back panel using the PH1 screwdriver.
即将完成!
结论
