跳转到主内容
Toshiba Satellite P55W-C5200X Keyboard Replacement
你所需要的
  1. Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 3 中的图像 2,2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 5 中的图像 2,2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 步骤 6 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 步骤 6 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, RAM: 步骤 6 中的图像 3,3
    • For this particular model of the device there will be two sticks of RAM.
    • There are two metal brackets holding each RAM stick in place. Carefully move the metal brackets outward on both sides at the same time.
    • Pull the RAM sticks out.
  7. Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 步骤 7 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 步骤 7 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement, Fan: 步骤 7 中的图像 3,3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  8. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  9. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 9 中的图像 2,2
    • Gently remove the fan from your device.
  10. Toshiba Satellite P55W-C5200X Keyboard Replacement, Keyboard: 步骤 10 中的图像 1,1
    • Once the fan, ram, and battery are removed, remove the motherboard.
    • Detach the three connecting wires.
    • Remove the white, blue-tipped cable ribbon too.
  11. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 11 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 11 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 11 中的图像 3,3
    • Remove the three wires that are connected to the motherboard first.
  12. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 12 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 12 中的图像 2,2
    • Remove the ribbon by using the black nylon spudger to avoid tearing the ribbon.
  13. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 13 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 13 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 13 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal bracket in place.
    • Gently remove the metal bracket.
  14. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 14 中的图像 3,3
    • Use the Phillips #00 to remove the four 8.0 mm screws that are holding the motherboard in place.
    • After removing all the screws, gently remove the motherboard.
  15. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 15 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 15 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 15 中的图像 3,3
    • Similar to step 4, there is a metal bracket that must be removed to get to some ports.
    • Use the Phillips #00 screwdriver to remove the three 5.0 mm screws that are holding the metal plate in place.
    • Gently remove the metal bracket off the ports underneath.
  16. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 16 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 16 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 16 中的图像 3,3
    • Once the ports are accessible, remove four connecting wires from the ports themselves.
    • Be gentle when removing the four wires.
  17. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 17 中的图像 1,2 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 17 中的图像 2,2
    • Once the connecting wires are removed, remove the 8.0 mm screw of the USB ports, using the Phillips #00 screwdriver.
    • Gently remove the USB ports.
  18. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 18 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 18 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 18 中的图像 3,3
    • Remove the thirty-three 1.0 mm screws with the Phillips Head #000.
    • Gently remove the metal cover.
  19. Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 19 中的图像 1,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 19 中的图像 2,3 Toshiba Satellite P55W-C5200X Keyboard Replacement: 步骤 19 中的图像 3,3
    • Gently pull on the tab to lift the keyboard from the device.
    • Lastly remove the keyboard.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G2
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 39
总计 1,403
