跳转到主内容
Toshiba Satellite P55W-C5200X Fan Replacement
你所需要的
  1. Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: 步骤 1 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 2 中的图像 1,1
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 5 中的图像 2,2
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 步骤 6 中的图像 1,3 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 步骤 6 中的图像 2,3 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: 步骤 6 中的图像 3,3
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  7. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 7 中的图像 2,2
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  8. Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite P55W-C5200X Fan Replacement: 步骤 8 中的图像 2,2
    • Gently remove the fan from your device.
结论
Marley Pusey
于03/27/19注册
147 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 UMass Dartmouth, Team S1-G2, Botvin Fall 2019 的会员
UMASSD-BOTVIN-F19S1G2
4 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 512
