当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the laptop over so the bottom is facing upward and the battery is on top.
Slide the tab below the battery to the left.
Slide and hold the tab on the right side of the battery to the right.
While holding the right tab, slide the battery upward and out its socket.
Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
Lift and remove the RAM slot cover.
To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
The RAM chip should pop up after releasing the tabs.
Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
To remove the second RAM chip, repeat the previous steps
取消:我没有完成这个指南。
与3其他贡献者
于02/03/14注册
271 声望
创作了2篇指南
徽章: 6
+ 3更多徽章
CPSU-AMIDO-W14S2G8
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 462
