跳转到主内容
Toshiba Satellite P205-S8811 RAM Replacement
你所需要的
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite P205-S8811 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P205-S8811 RAM Replacement: 步骤 2 中的图像 2,2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P205-S8811 RAM Replacement: 步骤 5 中的图像 2,2
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite P205-S8811 RAM Replacement: 步骤 6 中的图像 2,2
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite P205-S8811 RAM Replacement: 步骤 8 中的图像 2,2
    • To remove the second RAM chip, repeat the previous steps
结论
Davin
于02/03/14注册
271 声望
创作了2篇指南
团队
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G8
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 487
