跳转到主内容
Toshiba Satellite P205-S8811 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite P205-S8811 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Use a #1 Phillips screwdriver to take out the 8mm Phillips #1 screw holding the hard drive panel on.
  4. Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Place one finger under the tab of the hard drive panel and lift up with medium force.
  5. Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Hold the black tab attached to the hard drive and pull with medium force to the side that the tab is on. This will pull the hard drive out of it's socket.
  6. Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite P205-S8811 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Use a #1 Phillips screwdriver to unscrew the four 4mm Phillips #1 screws (2 on each side) holding the brackets to the hard drive.
    • With the screws undone, the brackets should come right off. Next, pull on the black tab again to pull the cover off of the hard drive.
结论
另外一个人完成了本指南。
Andrew Meyer
于02/03/14注册
245 声望
创作了2篇指南
团队
Cal Poly, Team 2-8, Amido Winter 2014 Cal Poly, Team 2-8, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G8
4 名成员
创作了7篇指南
一条评论
There is a missing step between 4 and 5.
- Remove the screw(s) that hold the HDD assembly in its compartment.
...only then can you move on to step 5.
Robert Cartier - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,084
