跳转到主内容
Toshiba Satellite P105-S6147 Motherboard Replacement
你所需要的
  1. Toshiba Satellite P105-S6147 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Begin by placing the laptop face down on a flat surface.
    • The battery is located in the bottom left hand corner of the device.
    • Slide the lock switch on the battery to the unlocked position.
    • Slide the release lever on the battery towards the lock switch. The battery should now rotate out of its dock in the laptop.
  2. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the casing located next to the battery.
    • Using a #0 Phillips screwdriver, remove the two 4 mm screws.
    • Use the precision tweezers to disconnect the white and black wire from the device.
    • Remove the thin black wire from the device.
  3. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Open the remaining casings using a #0 Phillips screwdriver.
    • Remove all visible screws on the bottom of the laptop to complete this step.
  4. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Hold the back cover slightly open.
    • Use the precision tweezers to disconnect the two ribbon cables at the bottom of the laptop.
    • Open the small black clips to free the ribbon cables.
    • Remove the back cover.
  5. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Locate the white plug in the upper right hand corner of the laptop.
    • Use the iFixit opening tools to apply even, backwards pressure to each side of the plug until the plug is free from the motherboard.
  6. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Locate the ribbon cable on the bottom of the laptop.
    • Open the small black clip that is holding the ribbon cable.
    • Gently remove the ribbon cable with the precision tweezers.
  7. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Locate the white plug next to the ribbon cable that was removed in the previous step.
    • Gently unplug the plug with your hand or the blue iFixit opening tools.
  8. Toshiba Satellite P105-S6147 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the motherboard from the laptop casing.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 358
