跳转到主内容
Toshiba Satellite P105-S6147 Keyboard Replacement
你所需要的
  1. Toshiba Satellite P105-S6147 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Use the iFixit opening tool to remove the cover at the top of the keyboard.
    • Insert the tool in the small space above the keyboard and gently pry until the cover pops out of its retaining clips.
    • Repeat the prying across the top of the keyboard until the whole cover is loose.
  2. Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Gently lift the cover off the top of the keyboard.
  3. Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove six 6 mm screws labeled “F4” at the top of the keyboard.
  4. Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Use the iFixit opening tool to pry the keyboard out of its retaining clips.
    • Insert the tool into the groove surrounding the laptop and pry until the keyboard “pops” out of the laptop body.
    • Once the keyboard is free from the laptop body, gently flip the keyboard over, as seen in the third picture.
  5. Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite P105-S6147 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Lay the keyboard down on the bottom of the laptop, as seen in image one.
    • Locate the ribbon cable connecting the bottom of the keyboard to the laptop. There will be a small black and white clip securing the ribbon cable to the laptop.
    • Use the iFixit opening tool to gently open the clip, freeing the ribbon cable from the laptop body.
    • Gently remove the keyboard from the laptop body.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 251
