简介
This guide will provide a walk-through on how to remove the screen in your Toshiba Satellite.
你所需要的
Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
Slide the unlock switch in the top left-hand corner to the left/unlock position.
Use the plastic opening tool to remove the four small rubber pop-out squares from the corners of your screen.
即将完成!
结论
另外一个人完成了本指南。
