跳转到主内容
Toshiba Satellite M55-S135 Screen Replacement
你所需要的
  1. Toshiba Satellite M55-S135 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the laptop so that it is closed, faced down, and the battery is facing away from you.
    • Slide the unlock switch in the top left-hand corner to the left/unlock position.
  2. Toshiba Satellite M55-S135 Screen Replacement: 步骤 2 中的图像 1,1
    • Hold the switch in upper right-hand corner to the right.
    • With the switch held open, pull the battery straight away from the laptop.
  3. Toshiba Satellite M55-S135 Screen Replacement, Screen: 步骤 3 中的图像 1,2 Toshiba Satellite M55-S135 Screen Replacement, Screen: 步骤 3 中的图像 2,2
    • Use the plastic opening tool to remove the four small rubber pop-out squares from the corners of your screen.
    • The laptop displayed in the picture does not have these plastic squares.
  4. Toshiba Satellite M55-S135 Screen Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite M55-S135 Screen Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips 00 screwdriver to unscrew the four 6.72mm screws from the corners of the screen.
    • The screws will be located underneath the previously removed black squares.
  5. Toshiba Satellite M55-S135 Screen Replacement: 步骤 5 中的图像 1,1
    • Use the plastic opening tool to pop off the black plastic casing that surrounds the screen.
  6. Toshiba Satellite M55-S135 Screen Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite M55-S135 Screen Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips 00 screwdriver to remove the two 6.72mm screws at the bottom left and right of the screen.
  7. Toshiba Satellite M55-S135 Screen Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite M55-S135 Screen Replacement: 步骤 7 中的图像 2,2
    • Turn the laptop 90 degrees clockwise.
    • Use the Phillips 00 screwdriver to remove the six 3.78mm screws from both sides of the screen.
    • Hold on to the screen while removing the screws.
  8. Toshiba Satellite M55-S135 Screen Replacement: 步骤 8 中的图像 1,1
    • Fold the screen down so that the back of the screen is visible.
    • Remove the yellow wiring connected to the top of the back of the screen by pulling it out and then up.
  9. Toshiba Satellite M55-S135 Screen Replacement: 步骤 9 中的图像 1,1
    • Use the Phillips 00 screwdriver to remove the 5.54mm screw connecting the green panel to the laptop frame.
  10. Toshiba Satellite M55-S135 Screen Replacement: 步骤 10 中的图像 1,1
    • Pull out the green panel and disconnect the black cable from the belly of the green panel.
    • The screen should be fully disconnected from laptop at this point.
结论
另外一个人完成了本指南。
Matthew Trinh
于01/31/13注册
63 声望
创作了4篇指南
团队
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G11
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 13
总计 1,125
