简介
The purpose of this guide is to demonstrate the process of removing a Toshiba Satellite M55-S135 laptop keyboard. For this process you'll need a flat-head screwdriver and a Phillips #00 screwdriver.
配件
无需配件。
  1. Start  with the laptop open and the keyboard facing you.
    • Start with the laptop open and the keyboard facing you.
    • Tilt the screen away from you to reduce the risk of damaging it as you remove the keyboard.
  2. Locate the vertical seam between the speakers and the top row of keys on the keyboard. Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Locate the vertical seam between the speakers and the top row of keys on the keyboard.
    • Insert the tip of a nylon spudger into the seam and slowly pry up the panel.
    • Be sure to gently pry the panel to avoid damaging it or the laptop.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver. Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
    • Remove both 6.72mm screws from the upper left and right of the keyboard using the Phillips #00 screwdriver.
  5. Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Use the nylon spudger to pry up the keyboard. Start with one side and then the other.
    • Be sure to pry gently with the screwdriver to avoid damaging the keyboard and keys.
  6. Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Gently lift the keyboard to reveal the keyboard cable located near the mouse pad.
    • Disconnect the keyboard cable.
    • Be sure to disconnect the cable before removing the keyboard to avoid damaging it.
结论
klismann Evora
于2014年03月12日注册
109 信誉积分
撰写一个指南
团队
UMass Dartmouth, Team 5-7, Cichon Spring 2014 UMass Dartmouth, Team 5-7, Cichon Spring 2014 的会员
UMASSD-CICHON-S14S5G7
4 名成员
创作了1篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 5
总计 444
