跳转到主内容
Toshiba Satellite M55-S135 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite M55-S135 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Use the Phillips 00 screwdriver to remove the 3.62mm screw.
  2. Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the plastic cover from the laptop.
  3. Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the black plastic tab horizontally away from the hard drive to disconnect and remove the hard drive from the laptop.
  4. Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips 00 screwdriver to remove the four 6.50mm screws on the sides of hard drive.
  5. Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Use the Phillips 00 screwdriver to remove the other four 6.50mm screws on hard drive.
    • Remove the washer strips (the metal strips that the screws held down) from the hard drive.
  6. Toshiba Satellite M55-S135 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Pull the black tab away from the hard drive to separate the hard drive and the casing.
结论
2等其他人完成本指南。
Matthew Trinh
于01/31/13注册
63 声望
创作了4篇指南
团队
Cal Poly, Team 7-11, Maness Winter 2013 Cal Poly, Team 7-11, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G11
4 名成员
创作了5篇指南
2条评论
I have a regular SATA 2.5 hard drive and it won't fit my M55-S1001. Is there something else I need??
Matthew Halbert - 回复
According to http://www.rakuten.com/prod/120gb-hard-d..., your hard drive is the right size. If it doesn't fit, check to see if the pins connect correctly and if your laptop accepts a SATA drive and not a PATA drive; this image can help http://www.laptopking.com/sata_identify.....
Next, check if you're inserting it correctly. I haven't experienced replacing the hard drive with the M55-S1001, but I assume it's the same method as the M55-S135 (though it could be different).
I'm unsure if there's anything else you would need besides the correct type of screwdriver to unlock the casing but I doubt it.
Matthew Trinh - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 3,935
