本指南有最近更改,您可查看未经巡查的最新版本。
简介
Learn to replace your wifi card.
你所需要的
Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
另外一个人完成了本指南。
