本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will illustrate how to replace your optical drive.
你所需要的
Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture.
Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
即将完成!
结论
