当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Carefully use the blue iFixit Opening Tool to pry the panel above the keyboard from the left and right side.
Push back the screen until it is flat with the laptop.
Gently remove the clips that connect the panel to the screen.
Use the Phillips #1 screwdriver to remove the two screws.
Gently pry the keyboard from the laptop using the blue iFixit opening tool.
Slowly lift the keyboard away from the laptop.
Remove the ribbon that connects to the laptop.
Ensure you remove the keyboard slowly to avoid damaging the ribbon cable.
Remove the 2-3 pieces of black electrical tape covering the black-and-white antenna cable.
Close the display, flip the laptop over, and disconnect the black-and-white antenna cables from the Wi-Fi card.
Flip the laptop back over and open the display.
Remove the two Phillips #1 screws securing the display hinges.
It is recommended to keep the screws in a small cup so that you don't lose them.
Remove the four Phillips #1 screws on the back of the laptop.
Gently pull up on the display's video connector to remove it.
Remove the black-and-white antenna cable from the groove.
Your display can now be removed.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
