跳转到主内容
Toshiba Satellite M35X-S114 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: 步骤 1 中的图像 1,2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Unlock the Battery from its Compartment: 步骤 1 中的图像 2,2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: 步骤 2 中的图像 1,2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Move the Battery's Release Switch: 步骤 2 中的图像 2,2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
  4. Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 步骤 4 中的图像 1,3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 步骤 4 中的图像 2,3 Toshiba Satellite M35X-S114 Hard Drive Replacement, Remove the Hard Drive screw: 步骤 4 中的图像 3,3
    • Locate the Hard Drive.
    • Locate the screw near the Hard Drive.
    • Use a Phillips 00 screwdriver to remove the 7.50mm screw.
  5. Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: 步骤 5 中的图像 1,2 Toshiba Satellite M35X-S114 Hard Drive Replacement, Slide the Hard Drive out: 步骤 5 中的图像 2,2
    • Please note that the hard drive from the laptop used is missing.
    • Slide the hard drive out.
    • The hard drive may not slide out easily, and may require a little bit of force in order to be disconnected from the laptop.
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 1,714
