跳转到主内容
Toshiba Satellite M35X-S114 Battery Replacement
  1. Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: 步骤 1 中的图像 1,2 Toshiba Satellite M35X-S114 Battery Replacement, Unlock the Battery from its Compartment: 步骤 1 中的图像 2,2
    • Locate the battery near the bottom left-hand side of the device.
    • Locate the two switches above the battery's top left corner.
    • Use any finger to move the smaller switch above the battery to the unlock position.
    • A small icon of a padlock will identify the "lock" and "unlock" positions of the switch.
  2. Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: 步骤 2 中的图像 1,2 Toshiba Satellite M35X-S114 Battery Replacement, Move the Battery's Release Switch: 步骤 2 中的图像 2,2
    • Use any finger to move the larger switch above the battery to the left and hold the switch.
  3. Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: 步骤 3 中的图像 1,2 Toshiba Satellite M35X-S114 Battery Replacement, Remove the Battery: 步骤 3 中的图像 2,2
    • Place your fingernail or fingertip into the groove near the top right of the battery.
    • Pull the battery out with your finger. Release the larger switch once the battery is out.
结论
Nathan Jansen
于09/08/14注册
206 声望
撰写一个指南
团队
CSU Fullerton, Team 2-4, Bruce Fall 2014 CSU Fullerton, Team 2-4, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S2G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 346
