简介
This guide will show you how to replace the screen of your laptop. Be sure to have an iFixit toolkit handy, or at the very least, a Phillips #0 screwdriver.
配件
无需配件。
  1. Unlatch the battery by pushing outward on both latches.
    • Unlatch the battery by pushing outward on both latches.
  2. Slide battery out.
    • Slide battery out.
  3. Remove the four rubber coverings at the corners of the screen frame to access the screws behind them. Using a Phillips #0 screwdriver, remove the four screws at the corners of the screen frame.
    • Remove the four rubber coverings at the corners of the screen frame to access the screws behind them.
    • Using a Phillips #0 screwdriver, remove the four screws at the corners of the screen frame.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Now you need to remove the bezel. This is the plastic frame around the screen. Gently pull it forward, and then upward to unsnap it from where it is connected at the hinges. The second picture shows what the laptop will look like thus far.
    • Now you need to remove the bezel. This is the plastic frame around the screen. Gently pull it forward, and then upward to unsnap it from where it is connected at the hinges.
    • The second picture shows what the laptop will look like thus far.
  6. Turn the laptop around so that you can view the lid. Gently pull the lid away from the screen so that you can view the white clips near the base of the screen, as shown in the picture.
    • Turn the laptop around so that you can view the lid. Gently pull the lid away from the screen so that you can view the white clips near the base of the screen, as shown in the picture.
    • Un-clip the three connections to disconnect the wiring.
    • Unsnap the lid as well at this point. It pulls away just like the bezel (the plastic frame) did.
  7. Remove the tape at the spots shown in the picture to detach the screen from the ribbon.
    • Remove the tape at the spots shown in the picture to detach the screen from the ribbon.
  8. Turn the laptop so the screen faces you again. Remove this screw, and the corresponding screw on the left hand side. Remove the four screws on the sides of the metal frame, located at the upper right and left, as well as the lower right and left.
    • Turn the laptop so the screen faces you again. Remove this screw, and the corresponding screw on the left hand side.
    • Remove the four screws on the sides of the metal frame, located at the upper right and left, as well as the lower right and left.
    • The screen may now be removed, and the replacement screen may be installed.
结论
Allison Collard
于2014年03月12日注册
111 信誉积分
撰写一个指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 748
