跳转到主内容
修复你的物品
维修的权力
商店
  1. Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Unscrew the three screws from the back panel with Phillips #0 screwdriver.
    • Remove the back panel.
  2. Locate the two clips holding the RAM chip in place. Apply pressure to each clip, pulling them away from the RAM. One end of the RAM will pop out.
    • Locate the two clips holding the RAM chip in place.
    • Apply pressure to each clip, pulling them away from the RAM.
    • One end of the RAM will pop out.
  3. Gently pull RAM out as shown. Gently pull RAM out as shown.
    • Gently pull RAM out as shown.
  4. To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • To intall a new stick of RAM, carefully insert it into into the RAM slot.
    • Gently push down on the RAM chip until it snaps securely into place.
结论
Michael Jensen
于2011年04月18日注册
425 信誉积分
创作了6篇指南
团队
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 的会员
CPSU-REGAN-S11S4G3
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 2,594
