跳转到主内容
Toshiba Satellite M305D-S4829 Keyboard Replacement
你所需要的
  1. Toshiba Satellite M305D-S4829 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Unlatch the battery by pushing outward on both latches.
  2. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide battery out.
  3. Toshiba Satellite M305D-S4829 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the five "F2" screws with a Phillips #0 screwdriver.
  4. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Insert the plastic opening tool above the F1 key.
    • Apply upward pressure until the black plastic strip snaps off. The entire strip will easily come off from left to right.
  5. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Find the screws above the F1 and INS keys.
    • Unscrew both screws with a Phillips #0 screwdriver.
  6. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Slowly lift the top edge of the keyboard out with your fingers.
    • The ribbon cable located on the back of the keyboard will become accessible.
  7. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 7 中的图像 1,2 Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Locate the black ribbon cable flap.
    • Detach flap with plastic opening tool. The ribbon cable will become free.
  8. Toshiba Satellite M305D-S4829 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Your keyboard has now been successfully removed.
结论
2等其他人完成本指南。
Michael Jensen
于04/18/11注册
425 声望
创作了6篇指南
团队
Cal Poly, Team 4-3, Regan Spring 2011 Cal Poly, Team 4-3, Regan Spring 2011 的会员
CPSU-REGAN-S11S4G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,550
