跳转到主内容
Toshiba Satellite L875D-S7210 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L875D-S7210 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Starting on either side, use a metal spudger to pry out the long, narrow plastic covering at the bottom of the keyboard.
  2. Toshiba Satellite L875D-S7210 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Gently remove the plastic strip from the keyboard.
  3. Toshiba Satellite L875D-S7210 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Using your hands, gently lift the keyboard out of the computer. The keyboard will still be attached to the computer so be careful not to pull too hard.
  4. Toshiba Satellite L875D-S7210 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Find the ribbon cable that connects the keyboard to the computer.
  5. Toshiba Satellite L875D-S7210 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L875D-S7210 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Place the metal spudger underneath the lockable connector.
    • Lift up to unlock the lockable connector
    • Remove the ribbon cable from the keyboard and you will have successfully removed from your laptop. Reverse this process to attach the new keyboard.
结论
Ian M Sloop
于10/20/18注册
667 声望
创作了4篇指南
团队
UC Davis, Team S7-G7, Lore Fall 2018 UC Davis, Team S7-G7, Lore Fall 2018 的会员
UCD-LORE-F18S7G7
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 729
