跳转到主内容
Toshiba Satellite L855-S5210 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L855-S5210 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove the screw that secures the hard drive and memory card bay.
  2. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the screw that holds the CD/DVD drive in place.
  3. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently pry and pull the CD/DVD drive from the bay.
  4. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 4 中的图像 1,1
    • There is a cut-out space in the CD/DVD bay. This is where you would use your finger to push and nudge the keyboard from its clip.
  5. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Turn the laptop right side up, open the LCD so the keyboard is exposed.
    • Firmly push the keyboard upward from the space in the CD/DVD bay. You should feel the clip being released from its hinge.
  6. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use a thin blade knife or spudger to release all the clips along the bottom edge of the keyboard.
  7. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 7 中的图像 1,1
    • After all the clips have been released, simply pull the keyboard downward to remove it from the top hinges.
  8. Toshiba Satellite L855-S5210 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the ribbon cable from the socket to remove the old keyboard.
    • To install the new keyboard, insert the ribbon cable and press the clips back in place.
结论
7等其他人完成本指南。
Trung Dang
于01/01/14注册
267 声望
撰写一个指南
5条评论
Where can I find a replacement keyboard? just search ebay, or is there a better option?
Zachary Coffin - 回复
I bought mine from eBay and just changedn it, and it's all groovy now.
look for replacement keyboard part no and get it.
Then watch videos how to unclip the keyboard and how to unclip the ribbon.
Then comeback and follow these steps here
chiedu7 -
@ Trung thanx you demysitified removing the keyboard.
Going in from the DVD/CD bay is a master stroke.
chiedu7 - 回复
I forgot please explain various ways to unclip the ribbon.
chiedu7 -
I own a Toshiba Satellite L850D model and I bought a replacement keyboard, but I am having a problem, I can’t get the friggin’ keyboard out! You guys make it look easy yet I am struggling to get out the keyboard. How should I do it? Also, how do get the trackpad working again? It no longer works now.
Aleck Erickson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 9,682
