跳转到主内容
Toshiba Satellite L855-S5119 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 步骤 1 中的图像 1,3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 步骤 1 中的图像 2,3 Toshiba Satellite L855-S5119 Optical Drive Replacement, Back Plate Removal: 步骤 1 中的图像 3,3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  2. Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 1,2 Toshiba Satellite L855-S5119 Optical Drive Replacement, Optical Drive: 步骤 2 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  3. Toshiba Satellite L855-S5119 Optical Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L855-S5119 Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
结论
另外一个人完成了本指南。
Tyler Shafer
于02/12/18注册
426 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 260
