跳转到主内容
Toshiba Satellite L855-S5119 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L855-S5119 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Hard Drive Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L855-S5119 Hard Drive Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L855-S5119 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Hard Drive Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L855-S5119 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Hard Drive Replacement, Back Plate Removal: 步骤 4 中的图像 1,3 Toshiba Satellite L855-S5119 Hard Drive Replacement, Back Plate Removal: 步骤 4 中的图像 2,3 Toshiba Satellite L855-S5119 Hard Drive Replacement, Back Plate Removal: 步骤 4 中的图像 3,3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,2 Toshiba Satellite L855-S5119 Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
结论
2等其他人完成本指南。
Monte Roden
于02/14/18注册
465 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 688
