跳转到主内容
Toshiba Satellite L855-S5119 Fan Replacement
你所需要的
  1. Toshiba Satellite L855-S5119 Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Toshiba Satellite L855-S5119 Fan Replacement: 步骤 2 中的图像 1,3 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 2 中的图像 2,3 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 2 中的图像 3,3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Toshiba Satellite L855-S5119 Fan Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 3 中的图像 2,2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Toshiba Satellite L855-S5119 Fan Replacement, Back Plate Removal: 步骤 4 中的图像 1,3 Toshiba Satellite L855-S5119 Fan Replacement, Back Plate Removal: 步骤 4 中的图像 2,3 Toshiba Satellite L855-S5119 Fan Replacement, Back Plate Removal: 步骤 4 中的图像 3,3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Toshiba Satellite L855-S5119 Fan Replacement, Optical Drive: 步骤 5 中的图像 1,2 Toshiba Satellite L855-S5119 Fan Replacement, Optical Drive: 步骤 5 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Toshiba Satellite L855-S5119 Fan Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 6 中的图像 2,2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Toshiba Satellite L855-S5119 Fan Replacement, Hard Drive: 步骤 7 中的图像 1,2 Toshiba Satellite L855-S5119 Fan Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Toshiba Satellite L855-S5119 Fan Replacement, Back Cover Removal: 步骤 8 中的图像 1,2 Toshiba Satellite L855-S5119 Fan Replacement, Back Cover Removal: 步骤 8 中的图像 2,2
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
  9. Toshiba Satellite L855-S5119 Fan Replacement, Fan: 步骤 9 中的图像 1,3 Toshiba Satellite L855-S5119 Fan Replacement, Fan: 步骤 9 中的图像 2,3 Toshiba Satellite L855-S5119 Fan Replacement, Fan: 步骤 9 中的图像 3,3
    • Remove the two 5mm screws on the fan assembly using a Phillips #0 screwdriver.
  10. Toshiba Satellite L855-S5119 Fan Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite L855-S5119 Fan Replacement: 步骤 10 中的图像 3,3
    • Unplug the fan's connection to the motherboard.
    • Lift the fan from the laptop.
    • Use a soft cloth to clean the dust away from where the fan was.
结论
另外一个人完成了本指南。
xu yan
于02/12/18注册
183 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 870
