跳转到主内容
Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement
你所需要的
  1. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 步骤 3 中的图像 1,1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 步骤 4 中的图像 1,1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement, Optical Disc Drive: 步骤 5 中的图像 1,1
    • Use the screwdiver and the Phillips PH00 to unscrew the three, 4mm screws for the RAM compartment
  6. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 步骤 6 中的图像 2,2
    • Use the Phillips PH00 to remove the 4mm screw that holds the ODD.
    • Slide the ODD outward.
  7. Toshiba Satellite L755D-S5150 Optical Disc Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the two 4mm screws and the plate attached to the ODD.
结论
团队
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 347
