跳转到主内容
Toshiba Satellite L755D-S5150 Motherboard Replacement
你所需要的
  1. Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
    • After shutting down your laptop, turn your laptop over and click the left tab left, then pull the right tab right as you pull the battery out.
    • This step should always be done before working on your laptop to minimize electrostatic shock.
  2. Toshiba Satellite L755D-S5150 Motherboard Replacement, Keyboard: 步骤 2 中的图像 1,1
    • Using the plastic opening tool carefully pry the plastic strip that sits at the top of the keyboard.
  3. Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use the Phillips PH00 to unscrew the four 4mm screws that holds the keyboard in place.
    • Using the plastic opening tool carefully pry your keyboard out without disturbing the cord underneath it.
  4. Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remaining is the cord that connects the keyboard to the motherboard. Remove this cord after the tabs are pressed in that releases keyboard.
  5. Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 Toshiba Satellite L755D-S5150 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Using the Phillips PH00 screwdriver remove the three 4mm screws from the cover for the RAM.
    • Use the Phillips PH00 to remove the one 4mm screw that holds the ODD.
    • Slide the ODD outward.
    • Removing the RAM is not necessary
    • The ODD is also commonly referred to as a CD-ROM.
  6. Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips PH00 screwdriver to remove one 4mm screw.
    • Use the Phillips PH00 screwdriver to remove the two 3mm screws from the fan.
    • The motherboard will be accessed from below the keyboard, therefore you will not need to take out the bottom of the laptop.
  7. Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the Phillips PH00 to unscrew the fifteen 4mm screws holding down the motherboard.
  8. Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 8 中的图像 1,2 Toshiba Satellite L755D-S5150 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the motherboard and disconnect the 4 pin connector on the bottom side.
结论
2等其他人完成本指南。
Shaheedah
于10/06/16注册
276 声望
创作了2篇指南
团队
USF Tampa, Team 2-5, Sullivan Fall 2016 USF Tampa, Team 2-5, Sullivan Fall 2016 的会员
USFT-SULLIVAN-F16S2G5
4 名成员
创作了5篇指南
一条评论
This my laptop for now .
mouhmmad ghassan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,030
