简介
To replace the Satellite L755 motherboard you will need a Phillips (PH0) screwdriver. The motherboard is fragile and should not be bent or pried away from other parts or forced into place since it may break.
你所需要的
Begin by unscrewing the screw located underneath the battery.
Then, unsnap and remove the bar above the keyboard.
Remove the 5mm Phillips #0 screw in the middle of the motherboard, and the 4mm Phillips #0 screw on the upper left near the fan.
Remove the four 4mm Phillips #0 screws under the edge covering flaps.
Carefully lift out the motherboard and fan.
To detach the fan, remove the two 2mm Phillips #0 screws.
另外一个人完成了本指南。
