跳转到主内容
Toshiba Satellite L675D-S7016 Top Case Housing Removal
你所需要的
  1. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Battery: 步骤 1 中的图像 1,1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 2 中的图像 1,1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 3 中的图像 1,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 3 中的图像 2,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 3 中的图像 3,3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Back Panel Removal: 步骤 4 中的图像 1,1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 5 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 5 中的图像 2,2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: 步骤 6 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Hard Drive: 步骤 6 中的图像 2,2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
  7. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 步骤 7 中的图像 1,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 步骤 7 中的图像 2,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal, Keyboard: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    • Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
    • Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
  8. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 8 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 8 中的图像 2,2
    • Remove the first 3mm screw with the Phillips #1 screwdriver.
    • Remove the next three 3mm screws.
  9. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 9 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 9 中的图像 2,2
    • Lift the keyboard gently . Slide it forward towards the screen and speakers. This reveals the connection needed for the next step.
  10. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 10 中的图像 1,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 10 中的图像 2,3 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 10 中的图像 3,3
    • Use the pointed end of the Heavy-Duty Spudger and push the pins toward the screen, leaving them in this position.
    • Carefully slide the connector out of the port.
  11. Toshiba Satellite L675D-S7016 Top Case Housing Removal, Top Case Housing: 步骤 11 中的图像 1,1
    • Remove the following screws with a Phillips #1 screwdriver.
    • Seventeen 5mm screws (recessed)
    • Three 2mm screws in the battery bay (flush-mounted)
    • Single 5mm screw does not need removal unless working on the screen
  12. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 12 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 12 中的图像 2,2
    • Remove five 5mm screws with the screwdriver.
  13. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 13 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 13 中的图像 2,2
    • Locate the trackpad connector.
    • Pull the ribbon from the connector.
  14. Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 14 中的图像 1,2 Toshiba Satellite L675D-S7016 Top Case Housing Removal: 步骤 14 中的图像 2,2
    • Pry under the top case housing along the perimeter with a plastic opening tool.
    • Be careful and gentle with this step, the clips you are releasing here are plastic and can be broken by violent prying.
结论
2等其他人完成本指南。
Austin Bons
于09/22/16注册
1,131 声望
创作了8篇指南
团队
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G2
5 名成员
创作了10篇指南
1指南评论
Great help this tutorial helped
Susan Scroggs - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 1,190
