简介
If your keyboard is unresponsive, or you are having some other issues with the hardware on the keyboard, this guide will show you how to safely remove if from the laptop. If you are unsure if the issue with your keyboard is a hardware issue, check out the troubleshooting page to find out.
你所需要的
Pry under the plastic strip, starting on the top right side of the key board with a Heavy Duty Spudger.
Once the first corner is raised, use your hand pulling upwards and release the rest of the strip.
另外一个人完成了本指南。
