跳转到主内容
Toshiba Satellite L675D-S7016 Hard Drive Replacement
你所需要的
  1. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the computer and unplug the power adapter.
  2. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Back Panel Removal: 步骤 4 中的图像 1,1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L675D-S7016 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  6. Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,2 Toshiba Satellite L675D-S7016 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Slide the hard drive to the left, using the silver tab.
    • Pull up the silver tab, removing the hard drive from the slot.
    • Do not touch the metal data pins on the hard drive or computer.
结论
To install a new Hard Drive, follow these instructions in reverse order.
2等其他人完成本指南。
Austin Bons
于09/22/16注册
1,131 声望
创作了8篇指南
团队
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G2
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,029
