跳转到主内容
Toshiba Satellite L675D-S7016 Disk Drive Replacement
你所需要的
  1. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Back Panel Removal: 步骤 1 中的图像 1,1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  2. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
  3. Toshiba Satellite L675D-S7016 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,1
    • Remove the single 5mm Phillips #1 screw using the screwdriver.
  4. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 4 中的图像 1,2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 4 中的图像 2,2
    • Push the exposed portion of the Disk Drive outwards.
    • The Disk Drive will begin sliding out of its slot. Remove Disk Drive from the laptop by hand.
  5. Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L675D-S7016 Disk Drive Replacement: 步骤 5 中的图像 2,2
    • This step is only necessary if there is a disc stuck inside the drive! If you are replacing the drive and do not need to remove a disc, this can be skipped.
    • On the front of the Disk Drive, below the eject button, insert a pin or paperclip into the hole.
    • Push the pin into hole until the Disk Drive pops out.
结论
另外一个人完成了本指南。
Austin Bons
于09/22/16注册
1,131 声望
创作了8篇指南
团队
UC Davis, Team 2-2, Oliver Fall 2016 UC Davis, Team 2-2, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G2
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 386
