跳转到主内容
Toshiba Satellite L675D-S7015 Disk Drive Replacement
你所需要的
  1. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop on a scratch free surface, exposing underneath the laptop.
    • Identify the unlocking latches denoted by the red circles.
  2. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L675D-S7015 Disk Drive Replacement: 步骤 2 中的图像 2,2
    • Simply slide the latches outward to the unlocked position.
    • The latches should stay in the unlocked position. If not, hold them in the unlocked position.
    • With the latches in the unlocked position, slide the battery out, away from the laptop.
  3. Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,2 Toshiba Satellite L675D-S7015 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 2,2
    • Remove the the screw shown by the red circle.
    • Lift and remove the panel shown.
  4. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the screw shown by the red circle.
    • Locate the small square that shows the back edge of the disk drive.
    • Push the drive in the direction shown until it cannot be pushed any further.
  5. Toshiba Satellite L675D-S7015 Disk Drive Replacement: 步骤 5 中的图像 1,1
    • Pull the now revealed part of the disk drive in the direction shown until the disk drive is released.
结论
Jared Smith
于03/24/19注册
231 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 108
