简介
If your device appears to be running hot on a consistent basis it is possible that you may have a malfunctioning fan. If the fan is filled with dust, broken, or damaged this repair guide will show you how to dismantle the device and replace the cooling fan.
你所需要的
Flip the laptop on a scratch free surface, exposing underneath the laptop.
Identify the unlocking latches denoted by the red circles.
Use a spudger to pry under the corner of the thin piece of plastic located above the keyboard.
Once part of the plastic guard is up, continue to pull up gently until the piece pops off of the laptop exposing 4 screws.
With the device flipped on its back, identify the screw shown and remove with Phillips head #1 screwdriver.
