跳转到主内容
Toshiba Satellite L655D-S5095 Screen Replacement
你所需要的
  1. Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L655D-S5095 Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 2 中的图像 1,1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Screen Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 5 中的图像 2,2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 6 中的图像 1,1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 7 中的图像 1,1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
  8. Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 步骤 8 中的图像 1,2 Toshiba Satellite L655D-S5095 Screen Replacement, Screen: 步骤 8 中的图像 2,2
    • Remove stickers from four corners of laptop.
    • Remove screws underneath stickers.
  9. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 9 中的图像 2,2
    • Use plastic opening tool to pry the hinges off.
    • Remove the screen cover.
    • Unscrew the six screws on the bottom of the screen near the top of the hinges.
  10. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 10 中的图像 1,2 Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 10 中的图像 2,2
    • Remove cable located next to the fan.
    • Fold down screen without screen back cover to remove cable as shown.
  11. Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 11 中的图像 1,2 Toshiba Satellite L655D-S5095 Screen Replacement: 步骤 11 中的图像 2,2
    • Unscrew both screws on each side of the screen.
    • Remove the screen.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 4-4, Calaway Spring 2014 UMass Dartmouth, Team 4-4, Calaway Spring 2014 的会员
UMASSD-CALAWAY-S14S4G4
4 名成员
创作了2篇指南
一条评论
Que éxito esta pagina , muy gran trabajo, soy de Perú y creo que este tipo de trabajos son muy bien valorados, saludos a la distancia.
Korregan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 20
总计 2,247
