跳转到主内容
修复你的物品
维修的权力
商店
简介
This guide replaces the RAM in your laptop and is fairly simple to complete.
  1. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop. Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
    • Remove the cover, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up. Push the two tabs outwards, away from the RAM. The RAM should spring up.
    • Push the two tabs outwards, away from the RAM. The RAM should spring up.
  4. Pull the top RAM stick out gently. Repeat steps 3 and 4 for the bottom RAM stick. When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
    • Pull the top RAM stick out gently.
    • Repeat steps 3 and 4 for the bottom RAM stick.
    • When installing the new RAM, line up the notches in the RAM's contacts and insert it at the same angle you removed it.
结论
8等其他人完成本指南。
Jerry Wakai
于2013年01月31日注册
362 信誉积分
创作了4篇指南
团队
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G7
5 名成员
创作了6篇指南
Thank-You! So Much!
Sandra Crockett - 回复
Awesome & Simple! Thank-you! My Model is a Satellite P105-S6147 1GBX2 DDR2-666 Sodimm 2BG Total.
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 3,399
