跳转到主内容
Toshiba Satellite L655D-S5095 Keyboard Replacement
你所需要的
  1. Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L655D-S5095 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the battery locks on the bottom of the laptop.
    • Slide the right lock outwards, until it locks into place.
    • Slide and hold the left lock outwards and hold it in place.
  2. Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 2 中的图像 1,1
    • While holding the lock in place, slide the battery out towards you.
  3. Toshiba Satellite L655D-S5095 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Using a #1 Phillips screwdriver, remove the 5.8 mm screw in the battery slot.
  4. Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to pry off the plastic panel above the keyboard.
  5. Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 5 中的图像 1,2 Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Unscrew the four 3.7 mm screws at the top of the keyboard using a #1 Phillips screwdriver.
  6. Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Slowly lift the keyboard out, up and towards the screen.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  7. Toshiba Satellite L655D-S5095 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Using a plastic opening tool, flip the ZIF connector up to release the ribbon and the keyboard.
结论
5等其他人完成本指南。
Jerry Wakai
于01/31/13注册
377 声望
创作了4篇指南
团队
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G7
5 名成员
创作了6篇指南
2条评论
Nice little guide. The only thing I can really think to add would be on the last part for those of us who are super-paranoid about breaking something. If you could add a picture of what the ZIF connector looks like after it's opened would help some.
I appreciate the guide, thanks. :)
Christopher Tidwell - 回复
Ditto on all of it. I think I broke my ZIF connector !! Help!! 😔
salirizz67@gmail.com -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 4,922
