跳转到主内容
Toshiba Satellite L55t-B5271 RAM Replacement
你所需要的
  1. Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L55t-B5271 RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 RAM Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L55t-B5271 RAM Replacement: 步骤 2 中的图像 2,2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 RAM Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L55t-B5271 RAM Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L55t-B5271 RAM Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 步骤 4 中的图像 1,3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 步骤 4 中的图像 2,3 Toshiba Satellite L55t-B5271 RAM Replacement, Back Panel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 步骤 5 中的图像 1,3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 步骤 5 中的图像 2,3 Toshiba Satellite L55t-B5271 RAM Replacement, RAM: 步骤 5 中的图像 3,3
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G3
3 名成员
创作了8篇指南
一条评论
I’ve got this exact model. Stock 6GB of RAM. However, I’ve attempted to upgrade to 8GB and have tried multiple sticks of RAM and no matter what, the computer won’t recognize it. I’ve ensured it’s locked in properly, RAM is functional, even factory reset. All to no success. Any ideas?
Steve B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 389
