简介
This guide will help you replace a broken motherboard in your laptop. It is a detailed process but this guide will allow you to easily remove and replace your motherboard.
你所需要的
在这个步骤中使用的工具:Anti-Static Wrist Strap$7.95
Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
Use the plastic opening tool to remove the back cover from the laptop.
Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
另外一个人完成了本指南。
