跳转到主内容
Toshiba Satellite L55t-B5271 CD Drive Replacement
你所需要的
  1. Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: 步骤 1 中的图像 1,3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: 步骤 1 中的图像 2,3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 3 中的图像 1,3 Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 3 中的图像 2,3 Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 3 中的图像 3,3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: 步骤 4 中的图像 1,3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: 步骤 4 中的图像 2,3 Toshiba Satellite L55t-B5271  CD Drive Replacement, Back Panel: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: 步骤 5 中的图像 1,2 Toshiba Satellite L55t-B5271  CD Drive Replacement, CD Drive: 步骤 5 中的图像 2,2
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  6. Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L55t-B5271  CD Drive Replacement: 步骤 6 中的图像 2,2
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
结论
团队
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 282
