简介
This guide will instruct you on how to safely remove and replace the hard drive of your Toshiba Satellite L55W-C5256. You may need to do this if:
- Your device’s hard drive is making a clicking noise, indicating component failure
- Your device will not boot or is displaying a blue screen of death
Before beginning this replacement guide, it is recommended that you use an anti-static work mat and that you ground yourself using an anti-static wrist strap. This helps to protect your device from damage caused by static discharge. If you do not have these materials, you can find an anti-static wrist strap here, and an anti-static work mat here. To learn how to properly use an anti-static band and an anti-static work mat (recommended), see the guide found here.
你所需要的
Flip the white part of the hard drive cable connector up.
Gently pull the cable out.
5等其他人完成本指南。
