跳转到主内容
Toshiba Satellite L505D-GS6000 Screen Replacement
你所需要的
  1. Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L505D-GS6000 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 2 中的图像 1,1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 步骤 3 中的图像 1,3 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 步骤 3 中的图像 2,3 Toshiba Satellite L505D-GS6000 Screen Replacement, Screen: 步骤 3 中的图像 3,3
    • Ensure that the battery has been removed and any wires are disconnected.
    • Open to a front facing position.
    • Remove screw coverings from casing.
    • Remove the M2 5x6 mm screws that under the screw covers that you removed using a Phillips #0 screwdriver.
    • Keep screws and covers together in a pile for easier reassembly.
  4. Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 4 中的图像 3,3
    • Carefully pry the screen covering out of place to remove it and set it to the side.
    • It may be helpful to use a plastic opening tool to assist in removal of the screen cover.
  5. Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 5 中的图像 1,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 5 中的图像 2,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the three M2 5x6 mm screws on each side holding the screen in place, using the Phillips #0 screwdriver.
    • Gently rest the screen on the keyboard, making sure not to damage any of the wires attached to it.
  6. Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 6 中的图像 2,2
    • Disconnect wire at the base of the screen from the laptop.
    • Be very gentle as to not damage any electrical components of the computer.
  7. Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 7 中的图像 1,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 7 中的图像 2,3 Toshiba Satellite L505D-GS6000 Screen Replacement: 步骤 7 中的图像 3,3
    • Peel back adhesive from the second connection to the screen and unplug the connection.
    • Remove secondary adhesive from the screen connection at the base of the screen.
    • Be cautious when removing the tape, as it will be reused for the replacement screen, so be sure not to rip it.
    • The screen is now free to be removed from the device.
结论
另外一个人完成了本指南。
Sean Hennedy
于03/20/18注册
124 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 663
