跳转到主内容
Toshiba Satellite L505D-GS6000 Key Replacement
你所需要的
  1. Toshiba Satellite L505D-GS6000 Key Replacement, Key: 步骤 1 中的图像 1,3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: 步骤 1 中的图像 2,3 Toshiba Satellite L505D-GS6000 Key Replacement, Key: 步骤 1 中的图像 3,3
    • Open laptop in the front facing position.
    • Use a plastic opening tool to remove the desired key from the keyboard.
    • When lifting up on the key, do so carefully as to not break the key or its housing underneath.
  2. Toshiba Satellite L505D-GS6000 Key Replacement: 步骤 2 中的图像 1,1
    • Use a finger to push a new key into place.
结论
If the key does not feel like it feels to be in the correct position, retry the process following the steps in order again.
Adam Dellicker
于03/19/18注册
539 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 434
