跳转到主内容
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
你所需要的
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: 步骤 1 中的图像 1,2 Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: 步骤 2 中的图像 1,1
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: 步骤 3 中的图像 1,1
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: 步骤 4 中的图像 1,1
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
结论
另外一个人完成了本指南。
Adam Dellicker
于03/19/18注册
539 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 10
总计 357
