跳转到主内容
Toshiba Satellite L505 Laptop Power Jack Replacement
你所需要的
  1. Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: 步骤 1 中的图像 1,3 Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: 步骤 1 中的图像 2,3 Toshiba Satellite L505 Laptop Power Jack Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 2 中的图像 2,2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 3 中的图像 2,2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 4 中的图像 3,3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
  5. Toshiba Satellite L505 Laptop Power Jack Replacement, Optical Drive: 步骤 5 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement, Optical Drive: 步骤 5 中的图像 2,2
    • Turn the laptop upside down.
    • Remove the screw labeled F4 using the Phillips #1 screwdriver.
    • There are 2 screws labeled F4, the correct screw is the one closer to the hard drive.
  6. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 6 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 6 中的图像 2,2
    • Gently slide the optical drive out of the device.
  7. Toshiba Satellite L505 Laptop Power Jack Replacement, Battery: 步骤 7 中的图像 1,1
    • Turn your laptop upside down, at the bottom of the laptop, slide the right sliding lock to the unlocked position.
    • Slide the left sliding lock to the left and hold it. Using your fingers lift the battery out.
  8. Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: 步骤 8 中的图像 1,3 Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: 步骤 8 中的图像 2,3 Toshiba Satellite L505 Laptop Power Jack Replacement, Palm Rest Assembly: 步骤 8 中的图像 3,3
    • Unscrew all of the screws marked on the underside of the laptop.
    • Remove the screw marked in the second photo by lifting up the lid and unscrewing using a Phillips #1 screwdriver.
    • Remove the three flat screws in the port where the Optical drive is housed in.
  9. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 9 中的图像 2,2
    • Remove the keyboard and once that has been done, remove the screw marked "16."
    • Disconnect all of the cables with a blue circle.
  10. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 10 中的图像 3,3
    • Using the opening tool, carefully go around the edge and loosen the palm-rest assembly, until you can comfortably and easily lift it off.
  11. Toshiba Satellite L505 Laptop Power Jack Replacement, Power Jack: 步骤 11 中的图像 1,2 Toshiba Satellite L505 Laptop Power Jack Replacement, Power Jack: 步骤 11 中的图像 2,2
    • Once the motherboard is exposed, gently unplug the power cord from the motherboard.
  12. Toshiba Satellite L505 Laptop Power Jack Replacement: 步骤 12 中的图像 1,1
    • Follow the cable to the power jack port and carefully lift up to remove it from the laptop.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 916
