跳转到主内容
Toshiba Satellite L505 Laptop Keyboard Replacement
你所需要的
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 2 中的图像 1,2 Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 3 中的图像 1,2 Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 3 中的图像 2,2
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 4 中的图像 1,3 Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 4 中的图像 2,3 Toshiba Satellite L505 Laptop Keyboard Replacement: 步骤 4 中的图像 3,3
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 23
总计 1,203
