跳转到主内容
Toshiba Satellite L455D-S5976 Optical Drive Replacement
你所需要的
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: 步骤 4 中的图像 1,1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 9 中的图像 1,2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 9 中的图像 2,2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 10 中的图像 1,3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 10 中的图像 2,3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 10 中的图像 3,3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 11 中的图像 1,1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 12 中的图像 1,1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 13 中的图像 1,1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 14 中的图像 1,3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 14 中的图像 2,3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 14 中的图像 3,3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 15 中的图像 1,1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: 步骤 16 中的图像 1,1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
结论
2等其他人完成本指南。
NateJohnson
于01/26/14注册
1,047 声望
创作了5篇指南
团队
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G26
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 1,156
