简介
The CPU is what makes the computer work. If it is not working properly, the computer may not turn on or work in the way in needs to. This guide will show how to replace the CPU through a series of steps.
你所需要的
Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
11等其他人完成本指南。
一条评论
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - 回复
