本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide is useful when you need to replace the wifi card due to it not working properly. In this guide, you will remove the wifi cover to access and then replace the wifi card.
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
你所需要的
Flip Laptop into an upside-down position.
Push latches (indicated in red) outward.
Lift battery by notch (indicated in green) to remove.
2等其他人完成本指南。
一条评论
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
